Stowy
Mar 24, 2022Follower
AP only mode w a Satellite - Android issues
I have a Netgear Orbi router installed and working in AP only mode by hooking in a switch port to my office network. It passes DHCP from active directory and DNS. The main and the satellite work gr...
Mar 25, 2022Guru - Experienced User
What orbi model are you referencing?
Be sure your devices are set for auto obtain IP addresses and DNS.
AP mode any Orbi system acts as a pass thru for internet traffic. Will not block internet services unless the RBR is not configured right for AP mode or the host router is not configured right or blocking traffic there.
What host router is being used?
How is the RBR configured for AP mode? Dynamic or Static IP?
