Retired_Member
Jun 29, 2021APN Issues - T-Mobile
I recently purchased an Orbi LTE LBR20 and have been using it with a T-Mobile data only SIM that I obtained directly from the T-Mobile store. For the first few days it has worked great with the auto...
Blanca_O
Jul 06, 2021NETGEAR Employee Retired
Hi Retired_Member
Welcome to NETGEAR Community!
We wanted to check if the issue re-occur after you have downgraded and upgraded the firmware to v2.6.4.2.
If so, there is a new firmware available. Kindly update the firmware to v2.6.5.2.
https://kb.netgear.com/000063807/LBR20-Firmware-Version-2-6-5-2
Blanca
Community Team
