Forthay
May 22, 2018Tutor
App Functions Disabled in AP/bridge mode
Hi, I’m still trying to find my BT Whole Home replace. I read the Orbi app has the following features
Set up your Orbi system
Enable Circle with Disney Smart Parental Controls to manage con...
- May 23, 2018
I am in AP mode and all of those functions are available.
May 22, 2018Guru - Experienced User
Those features should be available in AP mode.
There is no Bridge mode for the RBK50 series...
Forthay
May 22, 2018Tutor
Thanks FURRYe38 this really helps me, sincerely appreciated.
By chance, and only after your reply I found https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode too but it doesn’t explicitly refer to the app itself.
- tsigMay 23, 2018Luminary
- FURRYe38May 23, 2018Guru - Experienced User
I Think you'll be fine in AP mode...
- myraid1May 29, 2018Aspirant
Hello.
Can someone please tell me what I am doing wrong as I have my Orbi set in AP mode but cannot pause WiFi devices.
Thanks
- The_Dude1May 30, 2018Aspirant
I have an RBR20. I am in AP mode because I use a fios router downstream to convert MOCA to Ethernet. I can not use the AP either. App says plug in my router and turn it on.
