MattDX66
May 29, 2020Tutor
App no longer works
Have an orbi mesh which I connected to my virgin hub 3. All has been fine for a good few months until last week neither the app nor browser will connect anymore. I can see the orbi connected to my ...
- May 31, 2020
Did a reset - which did nothing. Unplugging the ethernet cable from the ethernet socket made it work however. At this point I did a bit of cable play and realised I'd also wired the ISP router to a switch that was on the same network so they were wired in basically a loop!
<insert face palm gif here!>
Thanks for all the advice - consider this case closed,
May 31, 2020Guru - Experienced User
Has a factory reset and setup from scratch been performed since last update?
MattDX66
May 31, 2020Tutor
- FURRYe38May 31, 2020Guru - Experienced User
Glad you figured it out. Please mark your thread as solved.
Enjoy. :smileywink:
