cramm
Mar 09, 2020Aspirant
App not connected when in Sattelite (RBS50) - AP mode
Hello community, I have a strange behaviour when connecting to satellite (RBS50) and wanted to discuss it with you. So, if i am connecting to the Router, the app goes fine, Detection of router is d...
- Mar 15, 2020Hi again ,
Daisy is off.
I have made it work when I connected the wan port for the uplink and not the lan port.
Why https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-Sy... is suggesting the lan ports?
To clarify things I am using the AP mode.
Thank you all.
Mar 09, 2020Guru - Experienced User
is the RBS correctly connected to the RBR and synced?
I checked mine this weekend and didn't see any issues with an iPhone and Android pad connected to the RBS while in the same room with the RBS. Devices seen on the app.
v2.5.1.8 loaded on both. AP mode.
