paulhand2
Jun 16, 2018Aspirant
Apple Airport as extender - no local network
Hi. I have setup my Orbi and satellite and all are working well. I’d like to extend the network to the garage which is some distance from the house. There is an Ethernet cable. I have connected an Ap...
- Jun 17, 2018
Thanks Guys
Just an update on what worked - seems the Orbi needed a firmware update. Once this was done everything played nice, without changes to my initial settings on the Airport.
My settings on the Airport (connected by ethernet to the Orbi via a switch):
Router mode: Off(Bridge Mode)
Network Mode: Create a Wireless Network
SSID/Password: Same as the Orbi network
Internet Connection: DHCP
Cheers
Paul
GadgetVirtuoso2
Jun 16, 2018Apprentice
You'll want to set up the Airport Extreme in the Airport Utility as extending the network. You will need to match the SSID and passwords you configured on the Orbi.
- paulhand2Jun 17, 2018Aspirant
Thanks Guys
Cheers
Paul
