HazardousTim
May 22, 2022Star
Apple computer Ethernet connection problems with Orbi
I have been seeing issues for a long time now with the Netgear Orbi RBR50 and Apple Ethernet ports connecting upon boot up. Even setting a Manual IP address over DHCP causes the connection to com...
May 22, 2022Guru - Experienced User
1. what firmware is on the orbi?
2. what modem/gateway is the router connected to?
3. is the mac connected to the router or to the satellite?
4. have you tried setting a reserved IP address for the mac?
- HazardousTimMay 24, 2022Star
1. Current Firmware version is 2.7.4.24. This is NOT inclusive to 1 person firmware version as I've had several updates and they all exhibit the same problem.
2. The router is connected up to an AT&T gateway. It's DHCP has long since been disabled and was set to a separate subnet prior to.
3. Connected directly to the router
4. I have set a reserved IP address on it as well. This did not change the symptoms.
- plemansMay 24, 2022Guru - Experienced User
Att gateways at notorious for issues.
Have you tried putting it (the att device) in router mode,disable its wifi, and put the netgears ip address into its dmz?
Or even with the att in router mode (wifi disabled) put the netgear in access point mode?
Yes I'm fully aware of the issues AT&T Routers can cause. I have long since disabled the wifi and put it in router mode and it is on another entirely different subnet.
Someone else suggested switching cables I may have to look into doing that. Not sure what else would be causing it and besides the router itself it is the only other constant.
