Deckard22
Jul 13, 2018Aspirant
Apple devices disconnect from satellite
Hello! My iPhone SE and iPad 2 seem to have trouble staying connected to one of my Orbi satellites. I can be sitting two feet away from the satellite and will drop a bar, and sometimes disconnect ent...
thebbandj
Aug 15, 2018Initiate
I have been struggling with my iOS devices showing full strength wifi, but no connection for some time now in a room that is equal distances from the router and satellite.
I had already disabled:
- Beamforming,
- MIMO-MU,
- Daisy Chain,
- Fast Roaming
And went in and changed the following settings:
- Set 20/40Mhz Coexistence to 40Mhz only.
- Changed CTS/RTS Threshold to 2307 for both 2.4GHz and 5GHz
The problem is gone. I am going to see if it is the combo of the two or just one, but very happy this is solved.
Aug 15, 2018Guru - Experienced User
Now what happens if you re-enable Beamforming only with those other settings?
- Beamforming,
- MIMO-MU,
- Daisy Chain,
- Fast Roaming
- Deckard22Aug 15, 2018Aspirant
Earlier, I did turn off all of the settings EXCEPT beamforming, and found no difference. Very frustrating! Thanks for your advice.
