Deckard22
Jul 13, 2018Aspirant
Apple devices disconnect from satellite
Hello! My iPhone SE and iPad 2 seem to have trouble staying connected to one of my Orbi satellites. I can be sitting two feet away from the satellite and will drop a bar, and sometimes disconnect ent...
thebbandj
Aug 15, 2018Initiate
I have been struggling with my iOS devices showing full strength wifi, but no connection for some time now in a room that is equal distances from the router and satellite.
I had already disabled:
- Beamforming,
- MIMO-MU,
- Daisy Chain,
- Fast Roaming
And went in and changed the following settings:
- Set 20/40Mhz Coexistence to 40Mhz only.
- Changed CTS/RTS Threshold to 2307 for both 2.4GHz and 5GHz
The problem is gone. I am going to see if it is the combo of the two or just one, but very happy this is solved.
Deckard22
Aug 15, 2018Aspirant
Thanks...I tried changing these, other than the 20/40 co-existance setting (which I couldn't find), and no joy. Where to you find that setting?
- FURRYe38Aug 15, 2018Guru - Experienced User
I believe theres is a 20/40Mhz check box under Basic/Wireless settings. Uncheck this to get 40Mhz.
- Deckard22Aug 15, 2018Aspirant
Thanks...I'll check that out!
