jwelch1213
Mar 27, 2020Aspirant
Apple iPhone unable to connect to wifi
We have an Orbi Router RBR50, iPhones are unable to connect to wifi. No option to forget IOS connection on the phone, any advice?
- Mar 28, 2020
What about other devices?
Really? iPhones should have that feature.
If you need more help, you might get better and quicker replies, and find other answers, over in the appropriate section for your device:
Orbi - NETGEAR Communities
No need to repost there, unless you want to – that will just clutter up the place with duplicated messages – but you might find advice related to your hardware.
I have asked the Netgear moderator to move your message.
michaelkenward
Mar 28, 2020Guru - Experienced User
- jwelch1213Mar 28, 2020AspirantThank you
- jwelch1213Mar 29, 2020AspirantThe IOS feature was located on the iPhone, disconnected but still same issue. Noticed this issue when work laptop brought home, VPN being used. Android phones, personal and work laptop connect without issues. Apple phones will not connect to wifi. Help
