bbrener
Oct 14, 2018Aspirant
Apple MAC Powers Down Orbi when it goes to sleep.
I have a friend with a very peculiar and frustrating problem. He has installed an ORBI RBR20 and all seems to be working well. It is connected to an Apple Macintosh desktop PC. When the Apple goes to...
Oct 15, 2018Guru - Experienced User
What FW is currently loaded?
What is the Mfr and model# of the ethernet switch if one is in the configuration.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Hoping NG support can have a look at this. So try this out as well.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
