mustangtexas
Dec 02, 2018Initiate
Apple products and the orbi mesh system
It sems all of my Apple products (iPad, iPhone, iMac) have wierd connection issues with my Orbi RBK50. They connect, but not everything work correctly. The iPad and iPhones will connect to the app ...
DDuss
Dec 02, 2018Guide
I had the same issue. When I set up my Orbi, I had my Uverse modem's wifi enabled and the Orbi working in router mode. Everything was working perfectly but my apple devices couldn't download or update from the app store.
I first disabled my Uverse modem's wifi but that didn't fix it. After doing some google'n I found out that I needed to go into orbilogin.com put the Orbi in AP mode. Now everything works perfectly
Dec 03, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- DDussDec 03, 2018Guide"configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode."
Does this have any benefit over AP mode?- FURRYe38Dec 03, 2018Guru - Experienced User
While in AP mode, most of the Routers features are disabled and not usable.
Does this have any benefit over AP mode?- DDussDec 03, 2018GuideI'd like to take my router out of AP mode. I think it throttles wifi speed.
How do I change the DMZ?
