mustangtexas
Dec 02, 2018Initiate
Apple products and the orbi mesh system
It sems all of my Apple products (iPad, iPhone, iMac) have wierd connection issues with my Orbi RBK50. They connect, but not everything work correctly. The iPad and iPhones will connect to the app ...
DDuss
Dec 02, 2018Guide
I had the same issue. When I set up my Orbi, I had my Uverse modem's wifi enabled and the Orbi working in router mode. Everything was working perfectly but my apple devices couldn't download or update from the app store.
I first disabled my Uverse modem's wifi but that didn't fix it. After doing some google'n I found out that I needed to go into orbilogin.com put the Orbi in AP mode. Now everything works perfectly
mustangtexas
Dec 03, 2018Initiate
Thank you for the reply. When I get back home this evening I'll give that a try. One of the inaccessible sites when using the Apple/Orbi combination was, ironically, the Orbi management page. I'll try on one of my PCs or switch my Mac to my cable company WiFi.
- FURRYe38Dec 03, 2018Guru - Experienced User
:smileywink:
