mustangtexas
Dec 02, 2018Initiate
Apple products and the orbi mesh system
It sems all of my Apple products (iPad, iPhone, iMac) have wierd connection issues with my Orbi RBK50. They connect, but not everything work correctly. The iPad and iPhones will connect to the app ...
DDuss
Dec 04, 2018Guide
Hey all,
I've gone through every setting and sub folder within my Uverse BGW210-700 modem and not once did I see a spot that allows you to change the DMZ. Could it be called something else?
- FURRYe38Dec 04, 2018Guru - Experienced User
Check for DMZ Plus and IP Passthrough?
https://www.att.com/esupport/article.html#!/smb-internet/KM1188700?gsi=qZc8BAU
Not sure if the article helps or not.
DDuss wrote:
Hey all,
I've gone through every setting and sub folder within my Uverse BGW210-700 modem and not once did I see a spot that allows you to change the DMZ. Could it be called something else?- DDussDec 04, 2018GuideI did see ip passthrough but there no was mention of dmz or DMZ plus in that section.
I'm new to networks so I apologize if I'm coming off completely clueless- FURRYe38Dec 04, 2018Guru - Experienced User
Might contact your ISP and ask them about DMZ. They will know. It's probably in the menu someplace. It will say DMZ or DMZ plus.
