mustangtexas
Dec 02, 2018Initiate
Apple products and the orbi mesh system
It sems all of my Apple products (iPad, iPhone, iMac) have wierd connection issues with my Orbi RBK50. They connect, but not everything work correctly. The iPad and iPhones will connect to the app ...
Dec 04, 2018Guru - Experienced User
Might contact your ISP and ask them about DMZ. They will know. It's probably in the menu someplace. It will say DMZ or DMZ plus.
ekhalil
Dec 04, 2018Master
DMZ+ and IP Passthrough are essentially the same feature with different names depending on the line of Gateway, the 2WIRE/PACE gateways called it DMZplus, the Motorola gateways called it IP Passthrough. What it does is:
1) Sends the public IP address that the Gateway receives from its upstream DHCP query to your downstream router in response to a DHCP request.
2) Passes unsolicited traffic that arrives on its WAN interface to indicated internal IP address without altering the IP address information
3) Passes traffic from the indicated internal IP address to its WAN interface without altering the IP address information
- DDussDec 04, 2018GuideDefinitely no DMZ/dmzplus in the menu.
I'm having trouble posting the pic so:
This is what is see from the IP Passthrough menu
Allocation mode - off (drop down box)
Default server internal address -e.g. 192.0.2.1 (text box)
Passthrough mode - dhcps - fixed (drop down box)
Passthrough fixed Mac address - e.g. 00:01:02:03:04:05 (text box)
Passthrough DCHP lease - e.g. 00:00:10:00 ( days hours minutes seconds text box)- ekhalilDec 04, 2018MasterI hope the following instructions will help:
https://forums.att.com/t5/AT-T-Internet-Equipment/Strict-NAT-Bridge-Mode-What-is-IP-Passthrough-Can-I-enable-on-my/m-p/5150658#M23293 - FURRYe38Dec 04, 2018Guru - Experienced User
Review this:
http://screenshots.portforward.com/routers/Arris/BGW210-700_-_ATT/IP_Passthrough.htm
You might contact the ISP and have them help you if you can't get IP PassThrough configured...
Passthrough DCHP lease - e.g. 00:00:10:00 ( days hours minutes seconds text box) - DDussDec 04, 2018GuideThis is great. Now I just have to sit down and really go through the walk through so I can fully understand what I'm doing.
Thanks- FURRYe38Dec 04, 2018Guru - Experienced User
If you get stuck or it doesn't work, make contact with the ISP. They should be able to help you with the modem settings.
:smileywink:
Thanks
