bobpenn
Jan 19, 2017Star
Apple products are slow
Many times during the day, my iPhone and iPad have very slow wifi, around 5 mb or less. If I toggle the wifi on and off, the both then receive at the full speed of 100MB. Happens after I reboot O...
JMU1998
Jan 19, 2017Luminary
For now you can try turning off beamforming and perhaps try 1.4.0.16 fw with factory reset and see if that helps, it helped me still unstable but not as annoying... Again this is just some temporary suggestions until next Firmware release hopefully soon
bobpenn
Jan 19, 2017Star
Thank you again. Too bad ... I thought this very high priced solution would be the answer to my problems. May go back to the Airport Extreme for now ...
