jp4120
Aug 04, 2018Guide
Apple TV airplay not working - is there a firmware fix?
never had a problem until installing ORBI system - spent 4 hours on this before coming here and seeing it may be a compatibility problem and there may be a firmware fix. i have a second generation Ap...
Aug 04, 2018Guru - Experienced User
Last FW fix was to help out Apple Home Kit problems...
How is airplay not working?
- jp4120Aug 05, 2018Guide
when i click on computer icon in Apple TV menu it says enable home sharing on the computer you wish to use as the source, i have the latest version of itunes installed and have homeshare enabled.
