jp4120
Aug 04, 2018Guide
Apple TV airplay not working - is there a firmware fix?
never had a problem until installing ORBI system - spent 4 hours on this before coming here and seeing it may be a compatibility problem and there may be a firmware fix. i have a second generation Ap...
Aug 05, 2018Guru - Experienced User
Was a power off of the router and satellite after the FW was updated performed?
Ensure your Apple Share is enabled correctly:
https://support.apple.com/en-us/HT201779
Last resort you might do a factory reset of the Orbi router and set up from scratch and see if this helps.
- AC641Aug 05, 2018Luminary
I have two Apple TV devices (3rd Gen) and have had occasional issues with them long before I got the Orbi. I rarely use Air Play but whenever I've had issues with streaming from my PC etc. I pull the power cable from the Apple TV and on reconnecting and rebooting it has always worked.
- jp4120Aug 18, 2018Guide
homesharing still not working correctly - have rebooted many times - apple tv listed as connected to Orbi when i go into admin screen. wonder if there is an advanced setting that is in conflict with it. I have a 2nd generation maybe thats not supported for some reason?
my Asus Win10 PC has latest version of itunes with home sharing enabled for my apple user id. My apple TV has home sharing enabled for same user id. When i go to computer on apple TV grid it tells me i need to enable home sharing on my pc.. I wonder if its apple tv device recognition that is at fault or if any else has any ideas.
