jp4120
Aug 04, 2018Guide
Apple TV airplay not working - is there a firmware fix?
never had a problem until installing ORBI system - spent 4 hours on this before coming here and seeing it may be a compatibility problem and there may be a firmware fix. i have a second generation Ap...
Aug 18, 2018Guru - Experienced User
You might ask about the new beta that the moderators have been asking users to help test out...
- jp4120Aug 26, 2018Guide
not afraid to admit a mistake, maybe this will help someone else.... i finally got around to troubleshooting a bit.
i was able to get home sharing with apple tv & itunes to work using a laptop, which told me that the problem was my network connectivity not my apple tv., I then realized i had not activated orbi access from my desktop pc (where i had my external drive with movies connected)....so obviously wireless home sharing won't work if you are wire connected only......
sometimes the obvious problem is the last one you think of...in the past my wired desktop auto connected to wireless also....Orbi changed that since its a separate system from the comcast modem.........all is working now.
- FURRYe38Aug 26, 2018Guru - Experienced User
Great information. Thanks for letting us know. Will keep this in mind.
