OrbiPhilip
Aug 19, 2020Luminary
Are Ethernet statistics available?
I am having a brief (~10-15 second) loss of service very roughly once an hour. Cable says it's between the modem and the router. That connection is a single ethernet cable, replaced. I can't see et...
CrimpOn
Aug 19, 2020Guru - Experienced User
OrbiPhilip wrote:Is there a means to get details statistics on ethernet frames? Not just RX/TX and collissions, but errored frames, CRC errors, etc.
There is an option on the Orbi "debug" page to capture every packet sent/received on the WAN interface. I often create a debug file and use Wireshark to look at the contents. At the very least, this would show if there is a 10-15 second "gap" in traffic once an hour.
