tokaton
Apr 09, 2025Aspirant
Are Orbi RBR50v2 router/satellites compatible with SXK30B3 router/satellites?
Netgear seems to have gone out of its way to create mass confusion between product monikers. I have an installed Orbi SXK30B3 system (router with 3 satellites), and I want to add additional satellites...
Apr 09, 2025Guru - Experienced User
- tokatonApr 09, 2025Aspirant
I knew someone would reply with that chart. Have you actually looked at it, and found the products I mentioned I have? If you would do so, you'd see the SK*** products are not included on it, so that page is useless to answer my question. Not to mention it doesn't explain how to install them in the existing network.
- FURRYe38Apr 09, 2025Guru - Experienced User
Can probably presume that they are not compatible. SX series is a AX feature that the 50 series doesn't have nor support. Also the SX series is a pro business system were the 50 series is home class.
- CrimpOnApr 09, 2025Guru - Experienced User
There is a similar table for the Orbi Pro models:
https://kb.netgear.com/000065558/Which-Orbi-Pro-routers-and-satellites-are-compatible
The answer is clearly, "no. won't work." Bummer.
