KraftyInSeattle
Aug 29, 2018Aspirant
Are there any hardware diagnostics for Orbi (RBK50)
I've been having ongoing problems for a little over a week with my RBK50 with two satellites after owning them for over a year and a half with no problems. I tried various firmware (including beta 2...
Sep 04, 2018Guru - Experienced User
You might contact NG support and ask for an RMA. Could be that you have a bad system is all.
KraftyInSeattle
Sep 04, 2018Aspirant
I've owned it for over a year and a half and I believe Netgear products, including Orbi, have only a one-year warranty and 90-days of support. Therefore I'm outside of the RMA window.
- cyberprashantSep 04, 2018Luminary
do u have stability if you don't attach any ethernet cables (for bridging) to the satellites? I think netgear is still sorting out issues iwth the ethernet ports on orbi.
