ryanpc's avatar
ryanpc
Guide
Jan 15, 2019
Are there any ideal Netgear Orbi settings for streaming 4K content over Wifi?
Plex and the like seem to be choking on any 4K/HDR content I throw at it. Assuming it's not the system (new Mac mini with fastest cpu) or the client (4K AppleTV), I'm wondering if something about my ...
  • ekhalil's avatar
    Jan 15, 2019
    The following Orbi settings can affect you maximum throughput:
    - WMM, a QoS setting which gives priority to media packets.
    - MU-MiMO: allowing multi spatial stream sending/receiving for devices that support MU-MIMO
    - Implicit Beamforming, which allows much better data transmissions boost in the mid-long range device setups.
    - If you can wire devices to Orbi then this will for sure give you better bandwidth.
