ryanpc
Jan 15, 2019Guide
Are there any ideal Netgear Orbi settings for streaming 4K content over Wifi?
Plex and the like seem to be choking on any 4K/HDR content I throw at it. Assuming it's not the system (new Mac mini with fastest cpu) or the client (4K AppleTV), I'm wondering if something about my ...
- Jan 15, 2019
The following Orbi settings can affect you maximum throughput:
- WMM, a QoS setting which gives priority to media packets.
- MU-MiMO: allowing multi spatial stream sending/receiving for devices that support MU-MIMO
- Implicit Beamforming, which allows much better data transmissions boost in the mid-long range device setups.
- If you can wire devices to Orbi then this will for sure give you better bandwidth.
ekhalil
Jan 15, 2019Master
ryanpc
Jan 15, 2019Guide
Awesome. #1 was enabled already. Enabled 2 and 3. Will test shortly :)
