flroots
Mar 31, 2020Guide
Are these RBR50 settings appropriate
I've recently purchased the RBK50. I read that these settings provide optimum signal strength and speed. Can anyone verify?
Ref: https://averagetechblog.com/how-to/netgear-orbi-settings/
- Daisy Chain Topology: Disabled (unless you have 3 or more satellites)
- MU-MIMO: Enabled
- Implicit Beam-forming: Enabled
- Fast Roaming: Disabled
- UPnP: Enabled
- WMM (WiFi Multimedia): Enabled
- Enable 20/40Mhz Coexistence: Enabled
1 Reply
Yes.
You can set 40Mhz Coexistence only. Uncheck the check box then apply.
