mlasky9679
Aug 09, 2021Aspirant
Armor Is Blocking a Website and Unblocking on Orbi App Doesn't fix It
Hi,
Up until yesterday I had no problem with a website that I login into for work. This morning when I tried I got the following error:
Stop!
Netgear Armor has blocked this website for your protection, it might contain malware, phishing, fraud attempt, or other forms of criminal...
We suggest you go back to safety
I would also get the following pop-up on my Orbi App:
Privacy Threat Blocked
Netgear Armor has detected that your computer is sending unencrypted authentication information and blocked that page.
When I click 'unblock URL' it says the URL was unblocked successfully but won't let me proceed to the website.
The only thing that fixed it was disabling Netgear Armor but I don't want that as the long-term solution, what else can I do?
Sort By
Netgear has set up a community forum specifically for the Armor product. Most of the people who watch that forum are more likely to have experience with Armor and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
https://www.netgear.com/landings/armor
Good Luck.- mlasky9679Aspirant
Thanks FURRYe38
đ
