jmrobles
Jul 06, 2020Aspirant
ARP table changes - ORBI RBR40 and three sattelites
RBR40 and three sattelites Firmware V2.5.1.16 2-6 times per day I see the following change in the ARP table IP:192.168.1.250, Old MAC: ??-??-??-??-??-18, New MAC: ??-??-??-??-??-90 The ??-18 MAC ...
jmrobles
GlassWire for windows network monitor
CrimpOn
Jul 06, 2020Guru - Experienced User
Well, this is indeed a puzzle. 192.168.1.250 does not respond to ICMP on my network (one Orbi router, one satellite).
When I attempt to ping it, the ARP requests are never answered.
192.168.1.250 is known to be an IP address that Netgear uses for configuring networking gear, primarily WiFi extenders. (Google search)
I got nothin.
- jmroblesJul 06, 2020Aspirant
The distance between the main router and the sattelite that is being swapped in the arp table is +-31 feet way with no walls in the way.
When I ping 192.168.1.250 I get no response from 192.168.1.250 but then 192.168.1.59 responds which is one of the three Sattelites and not the main router(RBR40). see below
Pinging 192.168.1.250 with 32 bytes of data
Reply from 192.168.1.59: Destination host unreachable.
Request timed out.
Request timed out.Appears to be internal to the ORBI system. Any ideas??
