UP4278
Jan 02, 2021Aspirant
Assign Guest Network to Satellite LAN ports
Hi there, I am wondering if it is possible to configure the LAN ports on the satellites to connect to Guest Network? I am hooking up a printer on that port, I would like it to be accessible from th...
- Jan 02, 2021
UP4278 wrote:Hi there,
I am hooking up a printer on that port, I would like it to be accessible from the guest network.
Router is RBR20, Satellites are RBS20.
A printer available only to the Guest network? Interesting. How about an inexpensive WiFi Extender, such as a TP-Link N300, available on Amazon for $20.
It has one ethernet port that can be used to connect a printer that lacks WiFi. Pair it to the Guest 2.4G network.
alokeprasad
Jan 02, 2021Mentor
Assigning guest network to the ethernet ports on the router or the satellites is not possible, AFAIK.
