carladj
Mar 24, 2020Aspirant
Assigned a Static IP - now dropping access daily
Our Orbi RBR50 was working great. However, I needed a static IP address for work. Once I got the settings from the ISP, I updated the settings with the app. Having done that, now the router loses...
CrimpOn
Apr 01, 2020Guru - Experienced User
carladj wrote:I have called my ISP 4 times. Everything looks good on their end.
When you talked to the ISP, did they say
(a) you are required to set up your router with a "static IP". (That's the only way it will work) Or
(b) your router can continue to use DHCP and they simply guarantee to give you the same IP every time.
I am too cheap to pay for a static IP, so I'd really like to hear what they tell you.
theoak
Apr 01, 2020Luminary
I get a static IP from my ISP. While my ORBI is in AP mode, there is nothing special I set on my router, it just gets the static IP from my ISP. I have CenturyLink DSL. Your ISP modem/router setup may be different.
- FURRYe38Apr 01, 2020Guru - Experienced User
Is your personal router set for Dynamic IP addressing on the WAN port while your ISP gives you a Static IP address?
theoak wrote:I get a static IP from my ISP. While my ORBI is in AP mode, there is nothing special I set on my router, it just gets the static IP from my ISP. I have CenturyLink DSL. Your ISP modem/router setup may be different.
- theoakApr 01, 2020Luminary
FURRYe38 wrote:Is your personal router set for Dynamic IP addressing on the WAN port while your ISP gives you a Static IP address?
Dynamic. However, my ISP always gives me the same IP.
What I'm hoping that the OP can do as well.
