jsurpless
May 08, 2022Aspirant
Assigning Static IP Address To Device Not Working?
I'm trying to assign dedicated static IP addresses to certain devices (namely, smart light switches). It appeared to work just fine for the 1st one, I didn't even have to reboot the device. But ...
jsurpless
Hi CrimpOn
Thanks for the reply - good point on the static vs reserved. My own OC will appreciate the distinction đ
It's not ideal but I found that rebooting the Orbi did the trick.
