nick77vet
Jul 25, 2018Tutor
Asus router in Media Bridge mode loses connection to Orbi multiple times a day
I am trying to use my ASUS AC-68U as a media bridge in my home office where I have several gateways that don't have wifi (SolarCity, Honeywell, etc.) plus my work computer connecting via ethernet cab...
Jul 25, 2018Guru - Experienced User
What channels are you using? Try manual channels 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any other wifi neighbors near by? If so, how many?
Any other wifi signals from near by devices?
Do other devices exhibit this same issue?
nick77vet wrote:
I am trying to use my ASUS AC-68U as a media bridge in my home office where I have several gateways that don't have wifi (SolarCity, Honeywell, etc.) plus my work computer connecting via ethernet cable. The ASUS router says it connects fine over the 5GHz band, with a speed around 900Mbps.
However, several times a day, it will lose the wifi connection. All the other devices connected to the Orbi are fine.
Is anyone else having this type of issue?
nick77vet
Jul 25, 2018Tutor
I am using channel 48 on the 5GHz band. The only other network being broadcast on the same or similar channel with any amount of power is the Orbi guest network, and I don't see a way to change that in the Orbi interface. Occassionally a neighbor's signal will show up with a power of about 90dBm. Another neighbor is using channel 155. That's it for the 5GHz spectrum.
I have several devices in the house that use the 5GHz signal, including all our phones. None of these devices have any issues with their connections.
I have an ASUS RT-AC66 router that I have also tried in media bridge mode, and it also suffered from dropped connections. Both ASUS routers have their latest fw, as does the Orbi router.
I have not tried a 2.4GHz connection, yet...
