sfjames
Jan 23, 2017Guide
At the end of my rope with my Orbi
Have been working with support to no avail. It goes like this. Orbi directly connected to my modem fills it log files with DoS Attack: ARP Attack] from source: xx.14.79.65, Monday, January 23, 2017...
Ely
Jan 23, 2017Luminary
You are worrying about some DoS/ARP Attack warning logs in your router? that's completely usual these days, almost everyone gets those every once in a while, I would worry if my router never warned me about those, does it bother you to see the logs? disable logs then, your Obi is doing exactly what it is supposed and designed to do.
sfjames
Jan 25, 2017Guide
Thanks for all your comments. While at the highest level I get it and thats what support is yackign about I would like it to make sense and I guess its just never goiing to. Let me be clear when my 7000 is the router alone with my modem and everything is connected exact.ly the smae way nothing in the log files for attacks. When you connect orbi it is attacked hundreds of times per hour all day long which does seem at times to effect performance. When you pur the orbi behind the 7000 again nothing in the 7000 or the orbi log files. IT doesnt make sense all things being equal. As I mentioned tried new ip addresses etc my casble company has been very accomodating in trying to help but has given up. They were concerned becasue all teh attacks appear spoofed from them thats teh trace on the ip but they say they are nto doing anything. Thanks.
- sfjamesJan 25, 2017Guide
Apologies for my quick reply and spelling mistakes!
- ElyJan 25, 2017Luminary
When your 7000 is the router as you say you don't see anything because your 7000 doesn't log DoS attacks, that's the only reason you don't see them, you seem them because it is a feature of your Obi to warn you about DoS attacks, but regardless of whatever the reason is, your Orbi has absolutely nothing to do with any and ALL attacks that might be happening in your network, the attacks will continue regardless of whatever router you have and wether you see them or not.
I resectfully disagree the 7000 does log those attacks as an occasional one does come through so that is not the issue and support confirmed it as well. They are baffled that even though they have different firewall's why the log files would be so different.
