sfjames
Jan 23, 2017Guide
At the end of my rope with my Orbi
Have been working with support to no avail. It goes like this. Orbi directly connected to my modem fills it log files with DoS Attack: ARP Attack] from source: xx.14.79.65, Monday, January 23, 2017...
Ely
Jan 25, 2017Luminary
When your 7000 is the router as you say you don't see anything because your 7000 doesn't log DoS attacks, that's the only reason you don't see them, you seem them because it is a feature of your Obi to warn you about DoS attacks, but regardless of whatever the reason is, your Orbi has absolutely nothing to do with any and ALL attacks that might be happening in your network, the attacks will continue regardless of whatever router you have and wether you see them or not.
sfjames
Jan 25, 2017Guide
I resectfully disagree the 7000 does log those attacks as an occasional one does come through so that is not the issue and support confirmed it as well. They are baffled that even though they have different firewall's why the log files would be so different.
- sfjamesJan 31, 2017Guide
Well been contacted for a beta version of firmware see if that does anythign will report back!
- MarkC1024Feb 01, 2017Luminary
Good to hear there is at least a new beta out for testing. Hope it helps with your issues and keep us informed!
- MachineLearnerMay 26, 2017Apprentice
Any success with the firmware beta? I am new to Orbi (2 days) and having a similar experience with DoS attacks in the log.
