northern1984
Mar 02, 2021Aspirant
Atem Mini Pro given 169.xx IP
I have an Atem Mini Pro connected via ethernet to an Orbi Satellite but given a 169 IP address.
Apologies in advance for my lack of understanding of networking. I am not very technical but below is the my set up and any checks I have done.
SET UP:
- Virgin Hub 3.0 in Bridge Mode
- Orbi Router (wired) to Virgin Hub in Router Mode providing IP etc.
- 2 x Orbi Satellites (1 downstairs and 1 in the office).
- These satellites are connected to main router wirelessly
Office:
- iMac connected via ethernet to Orbi Satellite - WORKS great.
- Atem Mini Pro via ethernet to Orbi Satellite - Not working. Given 169.xx IP.
Things I have tried:
- Put ethernet cable from Atem in to my iMac. My iMac still gets connectivity.
- Put ethernet cable from iMac to my Atem and Atem still doens't get connectivity - still given 169 IP.
- I have tried connecting the Atem to the router instead of the satellite - still given 169 IP
- I have unplugged my iMac from ethernet and turned on Wifi. I then plugged ethernet cable from Atem to my iMac, turned on internet sharing via Wifi using ethernet and the Atem finally gets a correct IP address of 192.xxx (but won't direct in to the satellite)
- I have rebooted the router - still no change
I have no idea why it's been given a 169 IP address when there is no problem with the cables or satellite is working fine and would really appreciate some help here if you can.
I have exhuasted my technical level so please, if any help advise me how / where I need to go to do what you suggest. It would be appreciated.
Thanks
northern1984 wrote:I have an Atem Mini Pro connected via ethernet to an Orbi Satellite but given a 169 IP address.
IP addresses starting with 169 are known as "Link-Local" addresses that are created by the device itself when it cannot reach a DHCP server.https://en.wikipedia.org/wiki/Link-local_address
Since the ethernet cables are good, my guess is that the Orbi may have Access Control enabled and will not allow new devices to connect.
p.s. I found the Atem Mini Pro user manual not particularly helpful in terms of how to connect to the network. For example, I did not find a section that describes how to put the device into DHCP vs. Static IP mode. (I quickly got confused between the Mini and the Streaming Bridge.You have both?)
- northern1984Aspirant
CrimpOn Thanks for taking the time to respond. I have checked my Orbi router settings and I have 'Access Control' turned off.
Atem (from Blackmagic) is really hard to understand. I have the Atem Mini Pro which is a Switcher. The Streaming Bridge connects to the Atem Mini and allows an external source to 'stream' there feed in to it so think 'remote guest' on a Facebook / YouTube live stream
I have since:
- Turned off DHCP -> Saved profile -> Turned it back on -> saved -> rebooted router.
Cheers
northern1984 wrote:I have since:
Cheers
Did this result in a connection?
If not, it might be a good idea to power off the Atem (or even 'reset' it?)
I am frustrated these days because my Windows 10 laptop fails to get an IP address when it 'wakes up'.
i.e. If I turn it on and it's connected to the router, it picks up the correct IP every time.
If I close the lid, and then later open the lid, wake it up, and log in, it does not get an IP.
I have recorded the LAN traffic in both situations. When powered on, laptop requests an IP, Orbi offers an IP, laptop accepts IP. Just as it is supposed to.
When I 'wake it up', the laptop keeps requesting an IP, Orbi offers IP, laptop requests IP, Orbi offers IP..... forever.
I can open the Windows control panel and use the Troubleshooter to "fix" the ethernet connection, but it's a pain.
My money is on something wrong with the Atem.
An alternative is to set a Static IP on the Atem. No DHCP that way.
Would not wonder if this link-local IP address is configured as a static IP - this the device does not use DHCP (when I remember right is active with the IP on 0.0.0.0.). Sorry, these are devices we dont get in our hands avery day. You could also challenge Blackmagic Design FMI.
schumaku Yes I am also challenging blackmagic so trying to resolve this both ends and see if its a Netgear or Atem problem
