swervenprotect
Aug 19, 2019Aspirant
AT&T Fiber and Orbi WiFi System (RBK30)
Hey everyone, I have AT&T fiber and have 2 wireless access points that's coming off the AT&T gateway.... I have a AT&T WAP that is used for their wireless tv boxes and I also have another WAP (old w...
Aug 20, 2019Guru - Experienced User
I would first ask the ISP if the ATT WAPs are specific to the wireless TV box or can these boxes work off a different wireless system like Orbi. Sounds like your ISP modem already has a bulit in router and wifi so if you add Orbi, you would need to disable wifi on the ATT modem/router unit if thats possbile.
The Orbi RBR unit would best operation while connected directly off the ISP modem/router.
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I would suggest trying Option #2 first, if this doesn't work well, you'll need to try Option #3 for the Orbi system.
swervenprotect wrote:Hey everyone, I have AT&T fiber and have 2 wireless access points that's coming off the AT&T gateway.... I have a AT&T WAP that is used for their wireless tv boxes and I also have another WAP (old wifi router) that I have wired from a switch that comes off the AT&T Gateway to extend the coverage. Should I replace the access point that I hooked up with the new Orbi router and maybe put the satellite in the basement for better coverage OR does the Orbi router need to come directly off the AT&T gateway without going thru a switch? Also, does the Orbi system use the same SSID as the AT&T Gateway? I really appreciate any info!!!! thanks!!
swervenprotect
Aug 21, 2019Aspirant
Thanks for in depth info!!!! I'll see what they say...
- FURRYe38Aug 21, 2019Guru - Experienced User
Let us know how it turns out.
