lhjlmm
Feb 28, 2020Aspirant
ATT fiber BGW210 and costco RBR50 RBS50
Hi, I've read through several of the forum posts and I think I have everything working, but I can't get into orbilogin.com. I followed these instructions. 1) I have a cable from one of the yello...
- Feb 29, 2020
It is almost never a good idea to have two routers back to back (Google "Double-NAT"). Because the BGW is used only for internet (no TV, no telephone service), it looks to like you have two choices:
- Unplug the BGW and use the Orbi instead of it. (Move everything from the BGW LAN ports to the Orbi LAN ports)
- Keep the BGW in its normal mode and install the Orbi in Access Point (AP) mode.
I believe that "Passthrough" will only work if the Orbi is the only thing connected to the BGW.
The first thing I would do is restore the BGW to its original state and verify that "everything works as before."
Factory reset the Orbi https://www.youtube.com/watch?v=cMw4ePACgc4
At this point, choose which path to take: replace the BGW or Orbi in LAN mode. My biggest consideration would be how much effort have I put into customizing the BGW. Have I assigned IP addresses to a lot of devices and do not want to go through that all over again?
- Yes. Then pick AP mode.
- No. Then it won't hurt to try replacing. (The BGW can always be plugged back in.)
To replace, unplug the BGW. Move everything from the BGW LAN ports to the Orbi LAN ports. Move the ethernet cable from the BGW RED (WAN) port to the Orbi YELLOW (WAN) port. Power on the Orbi and go through the setup. If something "goes wrong", then simply unplug the Orgi, move everything back to the BGW, and plug the BGW back in.
The AP option involves these steps:
- Plug the Orbi into the BGW.
- Learn the IP address asssigned to the Orbi.
- Use any web browser connected to the network to reach the Orbi web interface: http://<ip of Orbi>. The login will be "admin" and "password" (because it was reset to factory).
- Navigate to the Advanced Tab, Advanced Setup, Router / AP mode.
- Select AP Mode, Apply, and the Orbi will reset. (takes foreeeeeever).
- At this point, you can do the Orbi Wireless Setup and give it the exact same WiFi/password credentials as the BGW.
- Go back to the BGW and disable WiFi.
theoak
Mar 02, 2020Luminary
You have 2 options.
First:
1. Leave your existing modem essentially as is; however, go into the adminstration and turn off the wifi on your existing modem.
2. Connect your Orbi to the modem and put the Orbi in Access Point mode.
3. Place your Orbi satellites.
Notes:
Your existing modem will handle all DHCP, NAT, firewall, and whatever other features the existing modem will have.
Your Orbi system is essentially just providing wifi to your network, that's it.
Second:
1. Put your existing modem in a bridge or pass through mode; again, disable the existing modem's wifi if putting the modem in bridge mode does not automatically do that.
2. Connect your Orbi and ensure it is in Router mode.
3. You may need to configure your Orbi to log in to your ISP.
4. Place your Orbi satellites.
Notes:
Your existing modem is just there to get the internet from your ISP.
Your Orbi will handle everything else - DHCP, NAT, Circle, etc depending on what you want to turn on.
The Orbi may be able to do Circle and other stuff while in Access Point mode. I am not sure on that. I have my own UTM/firewall that handles all that.
lhjlmm
Mar 07, 2020Aspirant
If I use the 1st option in AP mode, can I hook up other devices on my RBR and RBS ports? And will wired backhaul work?
