mapalm418
Oct 11, 2021Aspirant
ATT Gateway and RBR20 Issues
I've posted several times regarding the ongoing issues I'm having with my Arris ATT Gateway and my Orbi RBR20 Router and Satellite. Now I'm at a loss. For 2 months, I had the Gateway in IP Passth...
Oct 12, 2021Guru - Experienced User
Be sure the wifi radios ARE fully turned OFF at the modem.
Be sure the placement between the modem and RBR using is 3feet or more in between them.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Is Armor or Circle enabled?
mapalm418
Oct 12, 2021Aspirant
FURRYe38 wrote:Be sure the wifi radios ARE fully turned OFF at the modem.
WiFi radios are currently on since I was experiencing issueds with connection: my Apple TV was buffering during streaming, which it hadn't doing before I turned rthe radios on.
Interesting. My Orbi Router is connected by ethernet to the ATT Gateway. They are sitting right next to each other. Could that be an issue?
I have 2.4 set to Auto and 5 set to 48. They have been like that forever.
There are probably 8-10 WiFi signals I am seeing nearby.
No Armor or Circle enabled.
