russellmoran99
Apr 20, 2017Luminary
AT&T MicroCell randomly disconnects using Orbi
I have an AT&T MIcrocell which is plugged into the Orbi Router firmware 1.8xxx to boost my AT&T signal. If you are not sure what a microcell is, it is designed for homes that have weak signal to boo...
MarkC1024
Apr 25, 2017Luminary
It's hard to say which end of the problem needs fixing. I'd start wth AT&T and ask them if their device can operate in an environment like Orbi, and examples if where it does.
MarkC1024
My previous assumptions about the microcell having a hard time with hand-offs might be off as it's generating it's own broadcast signal. However, the follow thread shows some promise:
