boymom2020
Mar 26, 2020Aspirant
At&t uverse with Orbi
I have an Orbi router and two satellite system (box says RBK43S) and my ISP is At&t uverse which provides a cable modem/router combination box. They do not allow it to be placed in "bridge" mode as ...
boymom2020
Thanks for the quick reply, do I have to reboot the Orbi router or do anything else after I turn off the ATT wifi options?
Sorry, Im no tech expert! :)
Mar 26, 2020Guru - Experienced User
You shouldn't have too reboot however it maybe a good idea to anyways.
After you get it setup, be sure to save off a backup configuration to file as well for safe keeping. Under Advanced Tab/Administration/Backup
Saves time if a reset is needed.
