only1mrsj
Apr 01, 2017Follower
AT&T Wifi / Hotspot
Hi! I have AT&T as my cell phone provider. I can't access their Wi-fi since my home sits on a deadzone - per AT&T. I use their Mobile Hotspot okay. Will the Orbi help me use the Wi-fi option or wil...
st_shaw
Apr 02, 2017Master
only1mrsj wrote:Hi! I have AT&T as my cell phone provider. I can't access their Wi-fi since my home sits on a deadzone - per AT&T. I use their Mobile Hotspot okay. Will the Orbi help me use the Wi-fi option or will I have to keep turning on the Hotspot? Will it work with the Hotspot? Thanks!
You can buy a 4G LTE router (like a MOFI or CradlePoint). It will connect to the AT&T service for Internet and provide WiFi throughout your house.
- TheEtherApr 02, 2017Guru
Ah, I forgot, Netgear also has a LTE router, the R7100LG.
