WPJoe
Mar 20, 2020Tutor
AT&T Wifi Calling
Hi - I have seen a number of threads on this topic and was hoping there was some resolution. We are an AT&T household and are users of the Wifi Calling feature. We have a single Orbi router, ...
- Mar 20, 2020
What mode is the Verizon router configured for? Router or Bridge mode? IF in router mode, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Mar 20, 2020Guru - Experienced User
Armor, Circle, Daisy Chain, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only by unchecking the box. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
- WPJoeMar 20, 2020Tutor
Thanks for the reply.
I am on 2.5.1.8
The Router it is plugged into is a Verizon FIOS Quantum router.
I will try the following and report back:
Armor, Circle, Daisy Chain, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only by unchecking the box. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).Is it important to do a full factory reset?
- FURRYe38Mar 20, 2020Guru - Experienced User
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- WPJoeMar 20, 2020Tutor
Thank you I will look into this as well.
I read about this when I first got the Orbi. I had Orbi Tech Support walk me through the setup and I think instead of disabling the Verizon router they had me rename the WIFI on that one to XXX-OLD and then name the Orbi WIFI to the name I had been using, so that my devices would connect to the Orbi. Then they had me REMOVE the Old Wifi connections from my devices.
Do you thinik this is not effective?
- Retired_MemberMar 20, 2020
WPJoe wrote:Thanks for the reply.
I am on 2.5.1.8
2.5.1.8 is your problem....get rid of it
