WPJoe
Mar 20, 2020Tutor
AT&T Wifi Calling
Hi - I have seen a number of threads on this topic and was hoping there was some resolution. We are an AT&T household and are users of the Wifi Calling feature. We have a single Orbi router, ...
- Mar 20, 2020
What mode is the Verizon router configured for? Router or Bridge mode? IF in router mode, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Mar 20, 2020Guru - Experienced User
Armor, Circle, Daisy Chain, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only by unchecking the box. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
WPJoe
Mar 20, 2020Tutor
Thanks for the reply.
I am on 2.5.1.8
The Router it is plugged into is a Verizon FIOS Quantum router.
I will try the following and report back:
Is it important to do a full factory reset?
- FURRYe38Mar 20, 2020Guru - Experienced User
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- WPJoeMar 20, 2020Tutor
Thank you I will look into this as well.
I read about this when I first got the Orbi. I had Orbi Tech Support walk me through the setup and I think instead of disabling the Verizon router they had me rename the WIFI on that one to XXX-OLD and then name the Orbi WIFI to the name I had been using, so that my devices would connect to the Orbi. Then they had me REMOVE the Old Wifi connections from my devices.
Do you thinik this is not effective?
Did they turn OFF the wifi radios on the ISP Modem?
They also need to either bridge the modem or use the modems DMZ for the Orbi RBR...
- WPJoeApr 02, 2020Tutor
Thanks to everyone for their help trying to troubleshoot this. I have tried the suggestions and wanted to report back to the group.
In the end, I think setting the Orbi to AP Mode seems to have been the most help. I am still testing but I think the consistency of the WiFi calling has improved noticeably since doing that.
For others having this problem - I did not have my FIOS router in bridge mode. Its frustrating because when I first got the Orbi I read the advice that you should not have both routers active at the same time, but Netgear Tech Support walked me through the setup and said that it would be fine this way.
But as people on this thread diagnosed, that setup can cause problems. And in my case, since I had not bridged my router, having the Orbi in router mode alongside my FIOS router seems to have been causing some issue.
Since putting it into AP Mode I have noticed and improvement in quality. Thanks for all the help. Will report back if anything changes!
- FURRYe38Apr 02, 2020Guru - Experienced User
Thanks for letting us know.
Yes, having two routers on line will cause problems. Glad AP mode seemed to have solved it.
You might check this out about your FIOS router at a later date:
Enjoy. :smileywink:
- Retired_MemberMar 20, 2020
WPJoe wrote:Thanks for the reply.
I am on 2.5.1.8
Armor, Circle, Daisy Chain, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only by unchecking the box. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).Is it important to do a full factory reset?
2.5.1.8 is your problem....get rid of it
