WPJoe
Mar 20, 2020Tutor
AT&T Wifi Calling
Hi - I have seen a number of threads on this topic and was hoping there was some resolution. We are an AT&T household and are users of the Wifi Calling feature. We have a single Orbi router, ...
- Mar 20, 2020
What mode is the Verizon router configured for? Router or Bridge mode? IF in router mode, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
CrimpOn
Mar 20, 2020Guru - Experienced User
WPJoe wrote:We are experiencing an issue where the Wifi Calling works well around some of the house, but when we move into our kitchen it suddenly drops and people cant really hear us. It seems to happen on my wife's computer as well, where its like we are losing connection and thn reconnecting.
Does going into the kitchen affect any other WiFi activity? (streaming video, for example) In addition to a plaster wall, kitchens are loaded with large metal objects that can block WiFi signals. Is it "everywhere" in the kitchen, or only in certain parts of the kitchen?
- WPJoeMar 20, 2020Tutor
My wife it seems like when she moves into the kitchen with her laptop it seems like the WIFI is momentarily disconnecting and then reconnecting....
- CrimpOnMar 20, 2020Guru - Experienced User
WPJoe wrote:My wife it seems like when she moves into the kitchen with her laptop it seems like the WIFI is momentarily disconnecting and then reconnecting....
My investigation would focus on these areas:
- Does the problem appear when the laptop goes into the "shadow" of a large metal appliance (refrigerator, wall oven, etc. is directly in the path between the laptop and Orbi)?
- Does the laptop "change WiFi bands" when this happens?
Looking at the Orbi web interface or Orbi "app", does the laptop connection change from 5G to 2.4G?
Bear in mind that the Attached Devices status does not update instantly.
My experience is that it can take 15-20 seconds for a change in status to show up. - What happens to something like video streaming?
Is there a reproducable pattern. i.e. YouTube stutters or stops when I get to this part of the kitchen? - I use Android phones, so I have access to many WiFi "analyzer" apps that show the actual signal strength, updated as often as every second. Would be interesting to have such an app open and walk around observing how the signal strength changes.
Or, it could be that AT&T WiFi calliing doesn't like kitchens? (nah)
- WPJoeMar 22, 2020Tutor
CrimpOn Thanks for your advice. I am trying to troubleshoot this.
When I go into my kitchen with the WiFi Analyzer App running it seems like the signal strength is still good (in the green zone).
I did notice that for some reason when I am in this app trying to chck signal strength, when it asks me to "Select AP" it lists 4 times my SSID that I am using. And maybe related, when I try to select my SSID on my computer from the list of available wif. Not sure where the "4" came from or why its there...I guess it corresponds to the fact that I see 4 different times my AP name in the Wifi ANalyzer app?
How would I use this to try and do the troubleshooting you suggested about whether the phone is jumping channels when near the large appliances?
I have also checked with the Orbi App as you suggested.
Both my phone and my wife's phone show as connected to 5GHz when in the kitchen near appliances, etc. I have full WIFI bars on my Android although she is not getting great coverage on her IPhone in terms of the WIFI bars (only 1-2 showing).
Thanks
