WPJoe
Mar 20, 2020Tutor
AT&T Wifi Calling
Hi - I have seen a number of threads on this topic and was hoping there was some resolution. We are an AT&T household and are users of the Wifi Calling feature. We have a single Orbi router, ...
- Mar 20, 2020
What mode is the Verizon router configured for? Router or Bridge mode? IF in router mode, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
