computersteve
Dec 24, 2019Apprentice
Attached Device List is not Updating / Working Correctly V2.5.1.8 AP Mode
Hello, The attached device list is not working correctly in AP mode on the RBR50 with the latest firmware.. Everything has internet, & all my satelites are connected but they all appear and say dis...
tomschmidt
Mar 09, 2020Virtuoso
lcona, do you have the RBR50 v1 or v2? Version 1 has a USB port on the back, version 2 does not.
lcona
Mar 09, 2020Aspirant
Oddly enough my original RBR50 is v1 and my replacement unit is V2 both are exhibiting this behavior.
- FURRYe38Mar 10, 2020Guru - Experienced User
How did you configure AP mode. Did you have the RBR and RBS already setup prior then changed the RBR to AP mode?
If so, Try a factory reset on both, this time, don't connect the RBS. Setup the RBR normally for router mode. Do this with a wired PC and the RBR disconnected from the host router. Once it's all setup, configure AP mode on the RBR. You can set a static IP on the RBR. Something I recommend and I do. Apply the change on the RBR and let it come to ready. Ensure the RBR in AP mode is working well. After this Power ON the RBS and get it synced to the RBR wirelessly. Ensure the RBR sees it as a connected satellite on it's web page. Check it's operation.
This is how I set my RBK50v1 up last weekend:
