Retired_Member
Nov 03, 2019Attached Device Rename not working
Hi All, I have contacted Orbi support with this one but they don't seem to have the answer I'm looking for. They have told me to try using the WEBUI Advanced Security -> Access list -> Not worki...
Nov 03, 2019Guru - Experienced User
its a known issue with the 2.5.0.38 firmware.
https://community.netgear.com/t5/Orbi/Orbi-Firmware-Update-2-5-0-38/td-p/1814184
https://community.netgear.com/t5/Orbi/Orbi-RBR50-Device-Names-not-Saving/m-p/1814717#M73473
You could roll back the firmware or wait for the newest firmware update to see if it fixes it.
Retired_Member
Nov 03, 2019Thanks.
Yeah that was my assumption also.
Well not such a critical bug still something many would like to have working.
Going to wait for Netgear to release a new firmware that fixes this. Btw how often are the firmwares updated?
Toube
Toube
- plemansNov 03, 2019Guru - Experienced User
there's been 29 updates since it was released. So quite frequently in comparison to other routers.
- Retired_MemberNov 03, 2019
Retired_Member wrote:
Thanks.
ToubeKeep one thing in mind, waiting for the next release may not do anything for you. NG now only pushes firmware updates that contain major updates. All others will show (as they did before), whether you install is up to you. Another guessing game..??
- Retired_MemberNov 03, 2019Retired_Member yeah I here you.
Well as I said this is more of a annoying bug and s long as the Router is working with the satellites in a stable manner then I'm goodđ
I'm coming from Asus aimesh and it was not an pleasent experience.
-Toube
