Retired_Member
Nov 03, 2019Attached Device Rename not working
Hi All, I have contacted Orbi support with this one but they don't seem to have the answer I'm looking for. They have told me to try using the WEBUI Advanced Security -> Access list -> Not worki...
Nov 12, 2019Guru - Experienced User
Care to give v40 a try? Looks like one user said the naming of devices seems fixed for him.
Retired_Member wrote:Hi All,
They have told me to try using the WEBUI Advanced Security -> Access list -> Not working
Advanced -> Setup -> Lan rename device -> Partly working.
For some reason some of the device are renamed and some not.
Anyone else having this problem?
I'm using the latest firmware and I have reseted to factory default 3 times to see if this helps but it has no impact on the problem.
I don't think it's a hardware issue because some of the devices are renamed.
Firmware: 2.5.0.38
Toube
kuno2501
Nov 24, 2019Guide
Having same issue since the latest update Router Firmware Version V2.5.0.38
Attached device name got messed up and cannot rename some of them, also cannot change access control of some of the attached devices!!
This update is terrible
- FURRYe38Nov 25, 2019Guru - Experienced User
Give v40 a try and see if this resolves this for you. Others have reported v40 fixed it for them:
I recommend doing a factory reset and setup from scratch on the RBR after updating FW. If this doesn't work for you, revert back to v30.
kuno2501 wrote:Having same issue since the latest update Router Firmware Version V2.5.0.38
This update is terrible- TokyoHamDec 04, 2019Aspirant
- TokyoHamDec 04, 2019AspirantJust wanted to chime in here. My RBK50 is still not allowing me to change device names on the .40 firmware, although previously stored names are finally showing up again (rather than just the MAC addresses) ... I did not do a factory reset because it would take hours to set everything back up again.
