Retired_Member
Nov 03, 2019Attached Device Rename not working
Hi All, I have contacted Orbi support with this one but they don't seem to have the answer I'm looking for. They have told me to try using the WEBUI Advanced Security -> Access list -> Not worki...
xlerate
Dec 17, 2019Guide
Ok guys, going to give this firmware a shot this afternoon.
netgear twitter support just DM me that there is a new firmware.
RBR50 / RBS50 Firmware Version 2.5.1.8
Note:If your firmware version is 2.2.1.210 or lower, you cannot update the firmware directly to v2.3 or higher. You must first update the firmware to v2.2.1.212 using the manual firmware update feature in the router web interface. After updating the firmware to v2.2.1.212, your Orbi router reboots, and then you can update to higher versions.
New Features and Enhancements:
- Enhances the device recognition mechanism of the attached devices list
- Add DAL into firmware for several features, like DIL, Armor.
- Include Fing for device recognition.
Bug Fixes:
- Fixes the compatibility issue with Sonos devices.
- Update the web server certification of RBR50/RBS40
Download Link:.
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V2.5.1.8.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V2.5.1.8.zip
Firmware Update Instructions:
To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click the Documentation button on the product page.
Dec 17, 2019Guru - Experienced User
Its working for me and others.
xlerate wrote:Ok guys, going to give this firmware a shot this afternoon.
- FURRYe38Dec 17, 2019Guru - Experienced User
Awesome.
Be sure to make a backup configuration to file for safe keeping.
Enjoy. :smileywink:
xlerate wrote:
FURRYe38 wrote:Its working for me and others.
Sweet.. just installed, so far, every custom name appears to be working, icons sticking also.
- tomschmidtDec 17, 2019Virtuoso
I upgraded my RBR50/RBS50 today from v2.3.5.34 to v2.5.1.8. Results thus far:
Good: Device naming bug of v2.5.0.x is fixed!
Bad: https certificate is still untrusted due to it being self signed, as seen in the image below from Firefox 71.0 from https://orbilogin.com/ which is the same self-signed certificate as seen in the v2.3.5.34 and v2.5.0.40 hot fixes. Netgear , please get a certificate authority to sign the certificate. Your previous certificate that expired in August 2019 was signed by a CA.
