SadisticMedic
Feb 17, 2017Aspirant
Attached Devices list is empty
I recently updated my network to version .34 and now my Attached Devices list is empty. Basic Home screen says 0 devices connected. Attached Devices list only shows the Satallite. Access Control gives me a blank screen. Advanced-Security-Access Control gives me a blank screen. Advanced-Administration-Attached Devices only lists the satallite.
I'm at a loss becuse I know there are numerous devices connected including the computer I am typing this on. Has anyone else had this problem? Anyone have any suggestions? I know it was working in the previous iteration of the firmware, but this is the first time I've needed to use the list since the update.
Any help or suggestions appreciated.
- tucsonticoVirtuoso
Did you reboot the router after the firmware update? If not, try that and be very patient. I recall it took an inordanately long time (10 minutes +!) for the router to display attached devicees. Also try typing in "orbilogin.net" in your browser to get another view of the devices.
- SadisticMedicAspirantThank you for your response. Yes, the router has rebooted several times since the update.
The .net pages show no devices either.
I used a LAN scanner, Fing, highly recommended, and it shows 25 devices including the router and satallite.- DarrenMSr. NETGEAR Moderator
Hello sadisticMedic
You may need to factory reset the router.
DarrenM
