chinjien
Aug 09, 2020Tutor
Attached Devices never show all the devices
RBK50 version 1 never show all the attached devices. Firmware is currently version V2.5.1.16 . Previously it can show all the devices. What actually happened?
- MstrbigMaster
chinjien wrote:
RBK50 version 1 never show all the attached devices. Firmware is currently version V2.5.1.16 . Previously it can show all the devices. What actually happened?Are you referring to all attached devices or all connected devices that are broadcasting..
The only devices that show are the devices that are broadcasting. A device that is attached but off, will not show.
- chinjienTutorHi, thank you so much for your reply. I am actually referring to the devices that are connected to Orbi Router and Satellites, wireless and wired, that are currently running, like the current iPhone that I am using to reply this in the forum. Even for this phone that I’m using that is connected to the WiFi to send this reply is not listed too. Anyway for me to fix this?
chinjien wrote:
Anyway for me to fix this?Mstrbigis correct that devices which are "connected" but inactive will drop off the Attached Devices display. For example, when I close the Nest "app", eventually my Nest thermostat no longer shows as "attached", even though it certainly is. This does not appear to be what you are experiencing.
Others have reported that the newer Netgear firmware has problems with Attached Devices and their solution was to manually install the previous firmware, version 2.5.1.8 My guess is that you are left with two options: (a) if the only issue you have with the Orbi is the accuracy of the Attached Devices display, you can just ignore it and hope that eventually all devices appear correctly, or (b) manually install 2.5.1.8.
